BFL13
Oct 30, 2013Explorer II
80-100 on 300 AGM vs 460 Wet taking the same time where both chargers are sufficient might be explained by the AGMs having a higher resting voltage? Acceptance rate goes up with Absorption Voltage so if the chargers have the same setting, the spread between battery and charger voltages would be less with the AGMs?
In bulk, both spreads would be more than can be used by the current limit of the chargers?
The smaller bank has higher R but being AGMs that's lower R so that evens out?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
