mena661
Oct 31, 2013Explorer
timmac wrote:WET's are better, see I can do that too. LOL! :)
Wow all these post about is AGM better than WET, I say YES, AGM is better, I never have to add water ever again..
full_mosey wrote:Why are you so stuck on this labor rate? Maybe it takes hours of your day to do proper maintenance but it takes me a few minutes every month max and that time is literally hooking up another charger for top charging. The charger does the work, I go back inside and play Battlefield 3. ONCE a year I check and fill with water, another 15 minutes max. I do this when I have ZERO else to do, I'm just sitting around the house and decide maybe I should do some battery maintenance. So out of an ENTIRE year, I spend maybe 20-25 minutes on battery maintenance. Sorry but that time is negligible and costs nothing. I spend an order of magnitude more time shoveling **** from the horses.
Did you intend to ridicule my request for a fair labor rate? It is my understanding that there are several procedures beyond adding water that are unique to wets to which a labor rate could be considered.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
