pnichols
Mar 19, 2018Explorer II
MEXICOWANDERER wrote:
AGM batteries do not dry out unless violently mistreated
- The batteries are sealed
- Special battery caps recombine oxygen and hydrogen and precipitate it back onto the glass mat
- Special relief valves built into the cap maintain pressure within the battery until a threshold is reached
- The caps then pop open, release pressure then automatically reseal: In practice it takes upwards of high 16's into the 17's of voltage to build up enough pressure to cause venting
- Prolonged excessive charging causes positive plates to shed
- It is because electrolyte in an AGM is extra potent 1.300 that the battery is sensitive to excessively high voltage.
I suspect that the pressure that makes the valves pop is vapor pressure that comes from too much heat build-up inside the battery. Too much heat built-up probably comes from too much current flow inside the battery.
The question is - what applied voltage values, versus air temperatures around the battery ... does it take to drive those too-high currents?
Lifeline told me that even too high of a float voltage applied too long can build up this internal battery vapor pressure to the point where the valves periodically open and reduce internal moisture via escaping vapor. What Lifeline didn't tell me was ... at what ambient air temperatures around their battteries does it take, versus applied float voltages in excess of their specs does it take, versus state of charge does it take when the float voltages begin to be applied ... for vapor pressure to eventually become high enough to open Lifeline's over-pressure valves.
The above physics probably also apply to charging voltages being used, versus average ambient air temperatues around the battery during charging, versus how high the average charging currents are during the charging.
Most likely all the above also applies to all sealed lead acid batteries - AGM or otherwise.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
