MEXICOWANDERER
Mar 20, 2018Explorer
The Tech Support gent also said he would play with my bank, and by somethings do in sort of a post mortem way, would be able to give me some indication of what I did to the bank. And that would then allow me to change my maintenance practices with more information.
THAT! is the mark of a first class battery company.
Like ROLLS, Lifeline revels in massaging and testing their products. They are ANYTHING but reluctant about flaunting their plate specifications.
And for Pnichols, a DPDT 30-amp relay can switch 120vac between power supplies. Use the NC for your normal charging and the NO for a Meanwell.
I have to do additional qualifying but my remarks about the 1500's output may be too conservative. The 1500 requires special HIROSE connectors to extend a cable for remote voltage adjustment. Not needed with fixed voltage.
The charger I am preparing, has an 11 position gold contact single deck switch for connection via a resistor network to the HIROSE connectors. Dedicated voltage setpoints.
10 amp delay start to allow pre-selected voltages to be seen and the units capacitors to charge before switching to load. A screamer to announce reversed cable to battery connection error. A EBP Pabst dual ball bearing fan -- 100,000 hour service life.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
