MEXICOWANDERER's avatar
Mar 18, 2018
AGM Batteries Do Not "Dry Out" Unless Physically Damaged
  • AGM batteries do not dry out unless violently mistreated
  • The batteries are sealed
  • Special battery caps recombine oxygen and hydrogen and precipitate it back onto the glass mat
  • Special relief valves built into the cap maintain pressure within the battery until a threshold is reached
  • The caps then pop open, release pressure then automatically reseal: In practice it takes upwards of high 16's into the 17's of voltage to build up enough pressure to cause venting
  • Prolonged excessive charging causes positive plates to shed
  • It is because electrolyte in an AGM is extra potent 1.300 that the battery is sensitive to excessively high voltage.
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 21, 2025
