MEXICOWANDERER's avatar
Mar 18, 2018
AGM Batteries Do Not "Dry Out" Unless Physically Damaged
  • AGM batteries do not dry out unless violently mistreated
  • The batteries are sealed
  • Special battery caps recombine oxygen and hydrogen and precipitate it back onto the glass mat
  • Special relief valves built into the cap maintain pressure within the battery until a threshold is reached
  • The caps then pop open, release pressure then automatically reseal: In practice it takes upwards of high 16's into the 17's of voltage to build up enough pressure to cause venting
  • Prolonged excessive charging causes positive plates to shed
  • It is because electrolyte in an AGM is extra potent 1.300 that the battery is sensitive to excessively high voltage.
  • 5+ years. I have no control over the charging, the ups is off the shelf rack mounting. Plug it in, turn it on, replacing battery pack when it says to.
    I pick through the used batteries in the pack. The few with really low open circuit volts have been cut open and found to be almost completely dry.
  • GordonThree wrote:
    I have plenty of physically undamaged AGM batteries that are dried out. Pulled from years of standby service from datacenter UPS.
    How many years are we talking?
    Would this probably be due to an incorrect charging schedule? If the caps are continuously venting, they will dry out quickly.
  • I have plenty of physically undamaged AGM batteries that are dried out. Pulled from years of standby service from datacenter UPS.
  • Hence even more need of temperature compensated charging.
    I'm so glad I no longer have to lay down in the snow to service my jars.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
