JaxDad
Jul 23, 2021Explorer III
NamMedevac 70 wrote:
I just had a similar problem with a 12 volt AGM truck battery.
After much failed troubleshooting I took it to auto repair shop and they replaced the battery end cables connecting to the battery post and this solved the problem.
Check those battery cables connection terminals as mine were rotten. Voltmeter and multimeter and other checks on the cable ends falsely showed proper start voltage flowing from the battery to the starter. Your mileage may vary. This info may be of help to others with battery start problems.
Good luck
Cam oohn.
All my testing and results were with the battery out of the vessel and on a test bench.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
