MEXICOWANDERER
Jul 24, 2021Explorer
Several areas but a single diagnosis. Useless. A trade in core
At one of 12 plate to intercell or post junctions conductivity has been permanently compromised. But just for fun let's do this. It's fast and cheap.
Drill 1/8" and (2) 1/2" long sheet metal screws.
Drill a hole straight down into the terminal the depth of the screw.
This is lead so when you attempt to screw down into the terminal keep it in mind
It is soft and weak.
If you can run the screw down and tighten it then a bad connection may be temporarily bypassed.
If your drill emerged clean then stage 2 would be to try 3/4 length screws. But this would be the last gap. I am trying to soothe an unknown style battery.
If it does work, it works. Many UL style batteries use post top caps.
And this will provide entertainment.
I am guilty of trying to repair things.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
