wa8yxm
Jul 24, 2021Explorer III
There are a few different ways batteries fail
Shorted cell (they never hit 12 volts)
high resistance (What you got is very very high resistance)
and as Mex said broken conneciton (Also very very very high resistance)
It's toast. replace it .
NOTE this assumes you are measuring voltage at the battery. if you are using a volt meter INSIDE the RV clean all connections first the problem might not be the battery.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
