MrWizard wrote:
well it is a matter of resistance
and if voltage is 13.6 ?
the AGM will accept more than the wet cell
How much ? difference IDK, i don't have the wet cells or equipment to properly do that test
I am trying to establish that at 13.6v (or any other voltage) the AGM will only accept more than the wet cell after the amps going into the wet cell start to taper.
I think it is misleading to just say , "At 13.6v, the AGM will accept more amps than the wet cell." If the wet cell is accepting the max amps of the charger, you can't get any more amps from the charger by swapping to AGMs
Context is everything here IMO.
