BFL13's avatar
BFL13
Explorer II
Nov 24, 2016
AGM vs Flooded Bulk Times
PT keeps asking whether AGMs will spend more time in Bulk at the same charging rate.
I found a good example where that can be measured, using ah64id's test with his PD4655 on his pair of Lifeline AGM GPL-6CT 300AH batts starting at 50% SOC.
He was able to get 55amps (averaging 56-54) for 90 minutes before amps tapered for the Absorption stage.
So that was 55/300 = 18.7% charging rate (same as 41 amps on 220AH)
And 90 min of 55 is 82AH plus 150AH =232AH/300 = 77% SOC
So compare that with my ugly graph numbers using Wets and we see that on the 220AH bank 18.7% rate is 41 amps and that hits the curve at 77% SOC.
Ta da! It is the same. AGMs and Wets are both the same kind of battery so why wouldn't they be the same? Anyway, that ought to answer PT's question, at last. :)
  • It does help though at least with my Lifelines that they can take as much charge rate as you want in bulk. My Magnum can do 125 amps and my two 220Ah 6V can take that easily vs my old wet cells at ~40 amps.
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 12, 2025
