BFL13's avatar
BFL13
Explorer II
Jun 12, 2017
AGMs and Inverter DC Voltage Sag -More Results
More on how AGMs do well under high amp draws for minimal voltage sag.
Recently put two 100AH AGMs in the truck camper and changed the little 120v 3.2 cu ft fridge out for a new to us Dometic 7401L. Have a 1000w Sharp microwave in the TC that came out of the 5er in another shuffle.
We have had threads before showing how AGMs do better than Wets for this job and how you can have two AGMs (which is easier in a small RV) where it would take four 6s for that smaller voltage sag- if you had room. So I did a test to see just where things are now in my TC.
I plugged the TC shore power into the 5er's MSW inverter so I could read the TC amps from the 5er's Trimetric. MW drew 117a DC and the fridge on 120 drew 13.4 DC amps.
Now plugged TC into TC inverter on the two AGMs (200AH). 1.0 voltage sag with the MW on presumed 117a. Got 0.1? sag not sure anything happened with the fridge at presumed 13.4a.
For comparison in the 5er with inverter drawing from four wets (430 approx.) and similar MW, I also get a 1.0 volt sag.
There are some differences in wiring etc, but for a general comparison, IMO this proves what has been stated before by those who have a couple of AGMs in their smaller RVs and are able to run high amp items no sweat.
The AGMs cost more, but for this kind of work they are perfect. Which is lucky, because they have to be inside our TC so we can't use Wets with their nasty battery gasses anyway.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
