- islandvagabondsExplorer120000 miles, checked all lines. Could feel air coming out of bag
- 77rollalongExplorerthere should be a part # on the bags them selves, had to replace one at the shop on Friday, had a new one in less than an hour. funny thing was it was only in the shop to have a taillight replaced when the rear bag exploded on our heavy tow truck..
- jjrbusExplorerWe are going to assume you checked all the air lines and schrader valves for leaks?
When I pulled my old bags they were marked with manufacturer and part #. Different RV so does you no good.
I had my RV layed up for a bit so sorted through the net and bought off brand bags off Ebay or Amazon?, a bit of a pain but can be done.
Here is a sight that might help https://www.stengelbros.net/Air-Springs--Hendrickson_c_287.html - Big_KatunaExplorer IIHow many miles?
Call Freightliner with your chassis number. My exhaust tip rusted out and Fleetwood sourced it but their markup is treacherous. - islandvagabondsExplorerA leak in the front left bag. All others look as bad or worse but not leaking yet. Firestone says replace after 10 years these are 16 years. It is time!!
Finding the part numbers on line is confusing because it is a motorhome not a straight truck. - Big_KatunaExplorer IICurious as I have an 05 on the same chassis; did you have a problem or preventative maintenance?
- 2oldmanExplorer IIGoogle finds some. Are those not the correct ones?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
