mike-s
Mar 14, 2018Explorer II
red31 wrote:They measured tongue weight toward the beginning, and in the comments said they "used a simple hydraulic scale to get the trailer's tongue weight", not one of the 1% accurate digital ones. So, that scale was apparently ~120 lbs. low. Considering that (and the weight of the bars), the rest of the weights were within a +-15 lb range, well within the scale's accuracy and resolution (which looks to be 5 lbs.).lawrosa wrote:
Hey its winter in NJ. I need something to do...
re watch and add up the weights for each scenario.
Baseline 11,585 lbs
Sag 11,695 lbs - 110 lb increased mass created out of thin air
leveled 11,715 lbs - more mass created
WDH 11,725 lbs - 10 lbs of spring bars
where o where did they measure TW, and why not compare to a ball a couple inches closer to the truck. This much effort and sloppy results.
For anyone who has a hard time understanding why the airbags increase the rear weight - they push down on the axle in order to push the frame up.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
