Dusty_RExplorerAug 23, 2020Air BagsOur mh has air bags on the rear axle. I'd like to be able to monitor the pressure in them. Would a pair of tire pressure monitors, the type that just screw on the tire stems, work OK screwed to the ai...Show More
valhalla360NavigatorAug 24, 2020Only thing to check would be if they will pick up and report at the pressures you run for the bags.MH is obviously different but in a pickup scenario, if you are running empty and drop the pressure to 5-10psi, are they calibrated to report that low.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
