Dakota98
Dec 26, 2014Explorer
I use a Porter Cable 6-gallon, pancake for both tires & winterizing. For winterizing the problem you will run into is the tank is too small & you'll need to purge the water lines 3-4 times allowing the tank to fill with air ea time in order to maintain your set pressure. Volume is more important than pressure. IMHO
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
