Hi All.. I want a air compressor to top off the truck tires to 80psi. And the trailer to 75psi. I found one that should work. It is a central air 21 gal.120ac, 14 amp. I want to plug into the power in...
That's a big fella. If your breaker holds against the startup load, which could be 50-60amps, it'll likely run. Would a compressor be an intermittent load? I think NEC sets limits for amp draw on branch circuits, 85% iirc.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
