Hi All.. I want a air compressor to top off the truck tires to 80psi. And the trailer to 75psi. I found one that should work. It is a central air 21 gal.120ac, 14 amp. I want to plug into the power in...
The Central Pneumatic Air Compressor is rated at 14 amps but, as stated above, the start up draw will be much higher. It's a fairly bulky compressor. We assume you do not plan on carrying it in your RV?
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
