Hi All.. I want a air compressor to top off the truck tires to 80psi. And the trailer to 75psi. I found one that should work. It is a central air 21 gal.120ac, 14 amp. I want to plug into the power in...
If you worried about it, and ain't in a panic. get a smaller one,...don't need a 14 amp to get 90 lbs. I have a 1 gallon pancake in the MH that pumps 100 lbs, and runs on a 175 watt inverter.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Oct 05, 2023
