path1's avatar
path1
Air compressors recommendations
My cheap air compressor needs replaced. I have heard that "Viair" compressors are very good. Not cheap but good.
If you have a Viair or did have one are they worth the money?
Or what is your recommendation for a air compressor.
Looking for 12 volt and it will stay in RV or pick up
Thanks
  • I have several Viair compressors. What are you wanting to do with compressed air? The larger Viair compressors are rated to 100% duty cycle up to 100 psi, above that the duty cycle drops. If running air tools, the compressor will need breaks, if filling tires, not so much. The biggest killer of compressors I have noticed is not violating the duty cycle, but running to small of wires for the load. As voltage drops, the amperage increases, given enough time that eats the windings internal to the compressor.
  • What power source do you have available? That makes more difference than anything else.
    I have a monster 12V air compressor, but it's cheaply built compared to a Viair system. Pay close attention to duty cycle.
    Details on mine here: http://2manytoyz.com/compressor.html
    My previous Class A had an onboard 5.5KW Onan generator. I used a Dewalt Emglo air compressor to fill tires, run an impact wrench, etc.
    Either of these compressors would fill RV tires. Someday I'll have my own Viair. Some of my off-road friends have them.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
