joem789's avatar
joem789
Air conditioner causing fridge temp to rise
After spending a few years in my 2003 KZ Sportsmen, this is the first year I have had to deal with temperature related issues with my fridge. I noticed it began having problems staying cold. I usually have my Norcold on 6. But just to keep things cold enough I have had to put it on 9. The highest setting. I chalked it up to the reason being the hot, humid weather we have been having. But had decided to do some experiments to get to the bottom of it.
At first I tried removing the rain cap to allow heat to move it faster. AT times I seemed to help. At other times, not so much. Then I tried leaving the cover off the back wall of the fridge. Also, putting up a tarp to keep the sun off that opening. I even put a small fan in there to help move air upwards better. This didn't really solve the problem.
The fridge does manage to make it down to 26 through the night when things cool down more. Today we had a mild day for a change. So I didn't run the ceiling AC. The fridge stayed at 27 all day long. Even after the sun came out to torture us. Later in the afternoon, I decided to run the AC. Not 10 minutes later, the fridge was showing 33. Then finally went up to 37, which has been typical. So I am thinking there is heat coming from somewhere in the ceiling that is affecting the cooling unit. Or is this just a coincidence?
Any ideas?
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
