j-d
May 23, 2017Explorer II
There'll be two MicroFarad values on the two-way RUN capacitor. An Appliance Parts or A/C repair Store should be able to provide it. As I said, you can buy just the HERM side, two single capacitors, or even one with the correct HERM value and a different FAN value and connect with a jumper to make them work together.
What are the two MicroFarad, may say uF, values? If Voltage is marked 370, a capacitor with the right uF and 440 volts will work.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
