uscgcolletti's avatar
uscgcolletti
Air conditioner issues
I have a Dometic thermostat and it seems it's completely off. The thermostat does not cycle till I have it past 50 degrees. I know this is incorrect and would like to get it fixed. Where is the sensor for something like this is it in the actual thermostat or elsewhere. I'm also thinking about upgrading to a digital. Any help you can offer is greatly appreciated
  • assuming you want to heat to cut off below 50 degrees
    what makes you think the T-stat is faulty
    what is the RV inside temp, 50, 60 , 49 ?
    the heat is not going to come on until the stat is set above room temp
    is the RV only 30-40 degrees and you want 45 degrees ?
    you have not given enough info
    heat pump or LP furnace
  • lenr's avatar
    lenr
    Explorer III
    Sounds like you have an analog or mechanical thermostat. You could upgrade that to a home style digital. Google for or check mod my rv. To use the Domestic digital you would have to upgrade the control box. The Dometic thermostat works fine for some and terrible for others having inconsistent temp control which was one of my problems with it. Don't suggest Domestic digital for an upgrade.
  • Only numbers I see is 310762-008. Actually on the card.
    Another is 0952, that's a sticker.
  • Need to know what Dometic tstat you have. They make about 8 different models. Doug
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
