infogeek
Sep 08, 2020Explorer
Rooftop Air Conditioner Issues
In June went on a trip, Roof air working fine for 7 days, when suddenly it wasn't. Blowing cool air but with an odor.  It was suggested to me it was the capacitor.  Since the MH had a few other maintenance issues I took it to a shop.  A few weeks later and a few hundred dollars they said squirrels had made a mess up there, all cleaned, working.  I had mentioned to check the capacitor but they never mentioned it.
In August took another trip. AC worked fine for 7 days, then same issue. Blowing air, but not cold, odd odor. Went up there myself and saw the capacitors not changed. (2000 Bounder 32H, original AC).
So I ordered a replacement and changed it out today. Since I don't have 30 amp shore power here, I fired up the generator. After running for a bit tried the AC. Seemed to kick on, but then seemed to have power issues, slowed fan, funny noise, obviously the generator was struggling (never an issue in the past, no problems running roof air before).
Shut it off, let the generator run a bit longer, tried again. Now it works when in FAN mode but when I kick it to COOL, nothing happens (no fan, no air, no noise, nada).
Questions: Did I blow a fuse? Is the AC just ****? Should I also replace the other ancient capacitors?
Not above letting a pro look at it or replace it if necessary. Any suggestions welcome.
