- Johno02ExplorerWe have 30' with just two slides, and in the temps now, both are running during the day. In a shady CG last weekend, Outside in the 90+ range, we did very well with only one AC most of the time. Most RV units have no provision for adding gas, some techs can do it, some say it can't be done. But you should get about 20 degrees drop from either unit. I leave topside vents open most of the time, so hottest air can escape, and small fans front and back to circulate air better through the coach.
- Grey_MountainExplorerTwo ACs. We are in a 39' pusher with 3 slides. In complete shade for the next 8 days. Dirty condenser? Where is the condenser? Assume it is on the unit on the roof. If I take the covering off, will I be able to see anything obvious?
As to low on coolant, have to wait until we get back home and get it into the shop.
GM - Johno02ExplorerFind a shady place. What you have is about it, but do check the in and out temps. Do you have one or two ACs??
- midnightsadieExplorer IIthe walls of a rv are not very thick some have no insolation , .
- sayoungExplorerMeasure the return air temperature then measure the discharge temperature and if about 20 degrees F +- couple a degrees, if so, then move to a cooler climate. If less than say 15D you might have a dirty condenser or possibly low on charge
Have good blinds on the windows, out in sun all day, etc ?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
