TZScales's avatar
TZScales
Air Tank Drain Valve
Greetings!!
In the process of draining my rear air tank I noticed a leaking drain valve which is located in the engine compartment. It has an air line connected to it that leads to the air tank. This was confirmed by spraying a soapy solution on the valve.
Is this as simple as removing and replacing with a new one? I know that I will need to drain the tank first and will not need to crawl under the coach.
Is a replacement easily attainable?
Thanks for any feedback.
  • TZScales,
    The answer mostly depends on what that one looks like. I bet that if you went to a truck parts place and described what you want, the counter guy would pull one off the shelf.
    They are typically on an 1/8 or 1/4 pipe thread.
    Matt
