woodland_park's avatar
Jul 18, 2017
Airxcel seems to take forever to cool park model
I have an Airxcel model 46413-812, that's mounted under my park model, that's always seemed to take a long time to cool our 500 sq ft park model. It's a 13,500 BTU unit, so it's plenty big..The park model has skirting all the way around the unit and the skirting is vented with 3 - 2' x 3' screens to allow airflow under the unit.There is no debris in the coil and the inside air return is clean. The airflow out the 4 vents seems very weak to me. It's 7 years old. I don't believe there's a high or low speed fan connection by looking at the diagram. The other day it was 91 degrees here and the A/C unit ran for 5+ hours before it turned off at 77 degrees.
Thanks for any comments
  • WOW! I feel so small! Thanks for all the replies. At least I have the comfort of knowing that it's not an issue with the unit. It's just too small. Wonder why Woodland Park would install an undersized unit especially since this model has a loft? Oh well, thank you all again!
  • A rig's roof broiling in direct sunlight will absorb "x" BTUs of direct solar radiation. If you can figure out a way to shade it while allowing airflow between the shade and roof top, it definitely will make a significant difference in the balance of heat extraction versus input.
    And remember it takes lots of energy to dehumidify air. My A/Cs spend the first half hour of operation reducing humidity. The water condensation of the evaporator coils contains all of the "cooling ability" of the unit. How much energy does it take to precipitate water from air? A lot. It is felt in the form of reduced cooling. It may pay to investigate the practicality of using a LARGE capacity dehumidifier if your inside humidity is 60% or above at ANY temperature. Changing the temperature of water (vapor) takes a lot of energy.
  • Too small of AC. You could use a free standing residential unit or get a second AC installed.
    Or even a ductless heat pump.
  • Our 12x40 Park Model has a 2 ton unit- ~24,000 btu, so I don't think you have enough capacity for that trailer.
  • not sure you have a problem or not. If your home was sitting idle in 91 degree heat before cranking up the AC it's going to take a long time to drop the temp to 77 especially with a single 13.5 BTU unit. Everything in the unit will need to cool down. Walls, furniture, appliances all retain heat. If you can test the air temp at a return duct and at a vent. If the air going into the return is 90 and the air coming out is near 70 then then AC unit is doing a decent job. But, pumping 70 degree air into a 90 degree house will take a long time to cool especially in the direct sun. If the AC unit keeps things nice after the initial cool down then don't worry about it.
    I'm not sure I would call a 13,500 btu unit plenty big for a 500 sqft park unit.
    at an average of 10' wide that means your dealing with a 50' long trailer.
    If you look at most rv's anything over 35' long usually gets a second AC unit and always gets a 15,000 btu primary.
    Remember most rv's have thin walls, and much less insulation than a sticks and bricks house, so the AC requirements will be higher than a comparable sized house.
    "Plenty big"? - for 500 sq ft?? Those owning travel trailers in the 30'+ range, which is half your square footage, will often start thinking about adding a second A/C for sufficient cooling. 'Though yours is a basement model it's hard to believe it's any more capable than a conventional 13,500 BTU roof mount unit and if so I'd say your expectations of this unit are unreasonable.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
