Bill001's avatar
Bill001
Airxcell Coleman's 13,500 btu Mach 8 Low Power Consumption
Hi,
I found the specs for Running Wattage on this unit, but I have not found a power consumption value when the unit is on low.
Does anyone know that, or measured it?
Thnx
Bill
  • Thanks All,
    That's exactly the info I was looking for
    Bill
  • Mach 8 13.5
    hi fan 1.3 amps 156 watts
    lo fan .7 amps----84 watts
    compressor at 95 degrees 12.5 amps---- 1500 watts
    FAN watts/amps do not change with outside temp
    COMPRESSOR Amps/Watts will change with outside ambient temp. Doug
  • Ah,
    I did not understand the question. Mine draws about 50 watts less on low. Measured with a Kill-a-Watt meter.
  • OK, just went out and measured my front AC, a 13.5 btu Mach.
    Difference between low and high speed (according to my EMS) is less than 1/2A.
  • My Dometic 13500 starts out at as low as 1100 watts and maxes out at about 1900 watts. Ambient temperature and run time both affect the demand.
    Low voltage may cause permanent damage to the AC unit. That is one reason I use an autoformer.
    You'd have to be more specific about your particular model as there are several versions of Coleman Mach 8 A/Cs. Also, RLA - Rated Load Amps varies depending on ambient temperature. If total draw is a concern you'd be far better off with a Coleman Mach 3 P.S. A/C.
  • I measured my Mach 15 last summer and the difference is pretty much inconsequential it's so small.
