Handbasket
Jul 09, 2014Explorer
Open, that's called 'thermosiphon' effect... same as a chimney, except for being a closed loop.
For me, it's always been about the sudden blast of noise that wakes me up, and the rather high battery drain. I don't mind sleeping cold, but I resent the very devil out of having to crawl out of that warm bed to turn the furnace on in the AM. I finally moved the thermostat to within easy reach of the head of the overcab bunk. I think my problem's solved, but I await next winter to find out.
If that doesn't work out for some reason, I've toyed with the idea of a hydronic system based on the existing water heater in my 19' Tiger CX. Just a thought experiment for now, but you can buy individual components made for water-cooling desktop computer CPU's (used by gamers & such). Small 12V pumps and fans and heat exchangers in various sizes aren't that expensive.
I want to find out what temperature drop I can expect to see over the various sizes of exchangers before I go much further. I might build a small unit for 'background' heat, just for the heck of it.
Jim, "Some days the best thing about my job is that the chair spins."
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
