Canadian_Rainbi
Mar 06, 2016Explorer
kokosfriend wrote:
OK! Checked the connections and they are not loose, but it still coulod be a bad battery or a converter that I can't find!!
Even if they are not loose there could be a bad connection due to corrosion under the clamps. Remove the cables, clean the inside of the clamps and the surface of the battery posts then reconnect. Do one at at a time OR take a picture of all the wiring so you don't have any problems when reconnecting them.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
