kokosfriend's avatar
kokosfriend
all DC appliances are failing!!! help
I have a 2014 Pallazo with the magnum inverter. My DC appliances have started failing. The LED lights are starting to flash, the TV controller shorted out, the Swintech control boxes have volts coming in and no power. I believe the system is getting AC into the DC. Have someone coming out tomorrow to help me check output on the system. Still have furnace and water pump, but figure they will go also. Has anyone experienced a melt down like this???
Barb - a gray haired old lady of 70 years!!!
  • I agree and I called Magnum tech support and the guy said it was also a converter!! I didn't get much help from him. It is model ME2012
  • Sounds like a CONVERTER issue.
    Isn't your Magnum inverter an INVERTER only? What is your model number?
  • Battery READs ok through the control panel
    The batteries are too difficult for me to check each separately but get 12-14 volt on the group. (coach not engine)
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
