acker1's avatar
acker1
Allison 3060
I always check my tranny fluid level with the shift pad on every stop when we are on the road. After my factory service at Freightliner last fall, my first check showed I was 2 quarts low. Checked dipstick and it showed that all was OK. I am getting ready to head north in about a month and want to resolve this before I head out. Freightliner had no explanation as to the cause. Maybe unhook batts for a while to reset the tranny? Any other ideas?
Before this the shift pad and dipstick always matched.
Thanks
DICK
  • Dick,
    Assuming transmission oil temperature was the same as earlier checks (where dip stick and electronic reading agreed) I agree with the recommendation to add a quart and recheck (making sure the transmission is up to temperature).
    Be sure to use the correct fluid-- Transynd if that is what is in there. Dexron III if not.
  • Allison tranny should be serviced at Allison shop for best results.
    Jim
  • Ivylog's avatar
    Ivylog
    Explorer III
    Add a quart to average your readings and do not worry about it.
