pianotuna wrote:
Hi Bob,
That is why my furnace is set for 12c (55 F). If the power goes out the furnace will take over the job from the electric heaters.
Bob/Olallawa wrote:
The problem I have with the electric heater option is when the 28* cold front moves in it just might take the power lines down too, then what.
That will work fine but I don't have all the nice solar stuff you have. If power is off for over a day my furnace will drain the two six volts if it is very much below freezing. That is a nice unit you added to the furnace. I drained the lines and will add the pink stuff today.
