twodownzero
Feb 21, 2019Explorer
The batteries will only take whatever current they are capable of taking. 136 amps would charge 2 golf car batteries in less than two hours from 0% SOC, but no battery will sustain that kind of charge rate. If I were you, I'd make sure your charge circuit is capable of 40 amps continuous (at least 8 gauge wire, bigger if the length is long) and call it a day.
The real question is, how much power do you need? If you're depleting your battery bank, you probably need more battery capacity before even thinking about how to charge them, especially if you already have 300 watts of solar.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
