twodownzero
Feb 25, 2019Explorer
ajriding wrote:upDon't make the wire too fat and too short and it will limit power to reduce load on the alternator.
If you build it for maybe 60 amps with #6 wire you should be fine.
So, a thin, long wire to battery is less demanding than a thick, short one?
Other guy, how are you monitoring the alt temps? do u have a gauge?
A significant voltage drop along the wire will reduce the current draw.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
