The Cb I bought, in 2012, is branded 'Absolute' and is the pushbuttonj disconnect/ lever reconnect type similar in appearance to Bussman's hi amp series.
I noticed when I added it, my maximum idle amps at the time were reduced by ~5.
I was noticing that Blueseas has relabbelled cooper/Bussman products and added some extra price to them.
I used to use the lever to see how much amperage increased when I switched the lever and closed the thicker parallel circuit with depleted house battery.
Much was dependent on how hot the 14awg fusible link in OEM circuit was at the time of switching.
Anyway I am glad that I finally had reason to move Hall effect sensor to a battery cable, and thaat I did not fully reassemble until I was sure I did not have to flip the sensor over( I did). Most all the mystery of how much total amperage the alternator was making disappeared a while back, but today was the hardest I pushed it with lights blower motor and a thirsty battery, and enough rpms to maintain 90+ amps output.
Now my dashboard mounted digital ammeter will show amps into or out of battery only.
