Landyacht
Please tell me more about your
"Transpo540HD adjustable voltage regulator modification still working awesome"
I am installing a home brew alternator voltage regulator modification. My 140amp Delco alternator uses the "S" terminal to determine the output voltage, normally the alternator puts out a constant 14.9Vdc without any temperature or SOC compensation.
I have a DCtoDC Boost device with via a switched connection (normal or override operation) to the "S" terminal. This device supplies an adjustable higher than expected voltage fooling the regulator to reduce it's output.
How does your system operate?
Where did you get it?
Thanks for the info
Edit - Found the links to the older threads but would still like to hear how things are working now and what if anything you might do different
Update located here http://www.cheaprvliving.com/forums/Thread-Your-Vehicles-voltage-regulator?page=2
