matt7591
Feb 26, 2017Explorer
Alternator Not Charging Chassis Battery
1996 Lazy Daze on a Chevy P30 chassis.
I have an alternator that is not charging. The simple answer might be that it is the alternator but these Chevies have an "exciter" circuit that determines whether the alternator charges.
I get 12.2 V on the battery with the engine on or off.
I don't get 13v+ with the engine on anywhere, including the alternator. Here are the voltages I get with the engine on:
Batt - terminal to terminal - 12.2
Alt red terminal to batt negative - 12.2
Isolator 1 - 12.2
Isolator 2 - 12.2
Isolator E - 11.7 (this is strange - lower than the others)
Isolator A - 12.2
Is it true that since I'm getting voltage readings my isolator is ok? Any suggestions on testing the alternator or anything else?
Thank you.
Isolator 1 - 12.2
Isolator 2 - 12.2
Isolator A - 12.2
Thank you.
