pyrosecur's avatar
pyrosecur
Alternator not charging house batteries Allegro V10 2004
Hi all !
Although my house batteries charge fine when plugged in or running on the gen set but they do not charge from the alternator.
I have verified all the solenoids and latching relay and evertything appears to operate properly. However I have located and tested the battery isolation solenoid (between the batteries and the alternator) and it is not getting any power when I turn on the ignition. When I apply 12V positive to the solenoid it operates.
What should I do to get power here ?
Tiffin Allegro BA32 2004
Ford V10
Thank you
Gerry
  • The coil for your isolator solenoid should be connected to your ignition switch through a fuse.
    So, find the fuse, and check to see that it's not blown.
  • There should be a DC circuit breaker on the engine batt side of the isolator Jumper it as a check
