larry_cad
Dec 07, 2016Explorer II
You didn't mention what type of coach you have. I just finished changing the alternator on my ISC. My problem was that the "Duvac" wire had broken off totally due to corrosion. However, in order to fix the problem, I had to remove the alternator and it was in very bad shape overall so replace it. Point is, the Duvac wire is critical to overall operation. This is a smaller, third wire on the back, in addition to the two bigger wires.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
