time2roll
Jan 31, 2021Nomad
DC-DC charger would provide two benefits. First in limiting your amps, secondly boosting the voltage to 14.5 or 14.6 to actually charge the battery to full. 14.1 is a bit low for most lithium.
Keep in mind the DC-DC charger can draw up to 50% more amps than rated output.
You could put your DC clamp-on ammeter on the charge wire or better the alternator output and see if you really get excessive amps. Test at home during the install. Then get the DC charger if needed.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
