dclark1946
Aug 29, 2013Explorer
BFL13 wrote:
If you need four batts to get by in winter with the furnace on all the time, then in summer you have plenty of battery to do extra stuff.
Also, with solar you can run the electric kettle and let solar make up the missing AH instead of burning propane using the stove top. This can be more convenient than going to get the propane refilled so often. Lots of factors by individual situation.
If you are camping where you are needing to run the furnace very much then the small amount of stove top propane consumption is not going to matter. In addition the waste heat from the stove top will help heat the trailer.
Dick
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
