mena661
Aug 29, 2013Explorer
rjxj wrote:500 lbs of batteries and hundreds of lbs of solar to make coffee from an inverter??? LOL! I hope this is an exaggeration. I have 400 lbs in batteries and I am in the VAST minority. Most people don't have half that weight in batts. Also, don't need that much weight in solar either. A big 270W panel weighs 44 lbs. That's overkill for most people. BFL13 has 270 lbs in batteries plus a ~30 lb 130W solar panel and he uses his MW with impunity. Also, that little bit of weight does not affect the TV at all period. I had my 400 lb batt bank in a lightweight 5th wheel (9500 lb GVWR) and I couldn't tell the difference with it installed or with a pair of grp 24's. My fuel mileage couldn't tell either and I live in a mountainous area too.
I considered solar/inverter but figured I would be lugging around 500 pounds of batteries plus hundreds in solar panels and wiring/components. The tow vehicle has to burn fuel to haul all the solar equipment and batteries.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
