3_tons
Aug 29, 2013Explorer III
Assuming your 2 T-105's are up to snuff, you Sir are experiencing only two problems. I also have 2 like sixers and solar...One problem is that my former Prowatt 2000SW was temperamental in this regard (voltage shutdowns - too low surge rating), once I switched it out for the costlier ProSine 2.0 high-load inverter tripping problems vanished completely.
The other problem is to eliminate any cable bottlenecks via short lengths and sufficient AWG size...Whether, Dirt Devil central vacuum, Keurig coffee maker (repeatedly) or microwave, I've since had zero problems using 4ought at 3' lengths and only 2 sixers. Batteries (again, assuming good) are not your issue.
BTW, per onboard metering, my 2 sixers often recharge via 440w solar at about 0.1 amp (< >) per every 35-50 seconds under ideal solar conditions. Pretty amazing!!
Best Regards,
3 tons
Best Regards,
3 tons
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
