NinerBikes
Aug 17, 2014Explorer
sjturbo wrote:
NinerBikes, I was not able to c&p the pages from the MFG. battery manual, but I will try again to link to the pdf. Page 5 discusses charging. FYI the mfg. indicates 100% SOC to be 12.6 or higher or 6.3 for 6v. Also SG 1.265 or greater. Link: Battery chargingThanks!
So, do you camp off the grid? Do you store your batteries off the grid too?
Key notes, for your Crown brand batteries.
14.5V to top charge.
15.5V to equalize charge, 1x a month, or so, when in heavy usage or deep discharges.
End results after an equalize charge should be at least 1.265 specific gravity for the battery acid. Slightly higher, I suspect, if the battery will do it (it may not?) would be anything over that, perhaps 1.270 or 1.275
1.265 Specific Gravity is supposedly your baseline.
Those are the numbers you need to engrave on your cheat sheet while you own these batteries. You need a device that has an adjustable charge controller voltage to make those numbers happen. 14.4V is close, but it is not 14.5V You should run 14.5V until your amps come down to a C20 charge rate on your battery pack.
I have zero experience with Crown Batteries. I have some experience with some tough loved Trojan scrubber T-1275 batteries. My T-1275's are somewhat unique.
I am going to defer to Mexico Wanderer. PM him if you have to, the voltage on those Crowns sounds a little low to me.
I would order that unit, pay the guy with a credit card or paypal, and get a few wiring bits, and get your pair of crowns fully topped off, and then equalized as a separate step. You do own a digital multi meter, and a good specific gravity meter?
Once you have the pair of Crowns fully "tuned up" charging wise, with a full 100% top charge and an equalize session, only then would I consider buying another pair of Crowns. Learn to maintain what you currently have, correctly, before starting in on a new, very expensive pair of Crown Batteries. Your money... but that little unit, if you adjust with and get the voltage right, should very well do the job. Sometimes, just by pushing the voltage a little bit, you can accomplish things that all the amps in the world at a lower voltage just won't get done, chemically speaking with lead, and sulfur and H20, in terms of getting that sulfur completely off the plates, as best you can, before it hardens and gets really stubborn.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
