sjturbo's avatar
sjturbo
Am I shortening my battery life?
We have not been able to go out much in the last year so I have kept the 53r plugged in at home. I check the two Cr235 6v batteries monthly and top off as needed (which is not much). The 5er has a WFCO 8955 which I know is not very popular regarding bulk mode. Question is am I shortening the battery life by keeping it charged up, ~13v instead of occasionally running it down to 50 0r 60% and hoping the bulk charge will kick in? Also what effect is not equalizing them monthly or weekly having? I know there are many thoughts on this so I hope to hear your opinions.
  • Very hot this time of year! I have been checking the water regularly with little to no water needed in any cell. I have not checked the SG in about a month but is was fine then. I will check again tomorrow and compare it to Crown specs. Thanks! I believe the float is about 12.2v or 12.3v. When I checked the battery voltage about 1.5hrs after flipping the disconnect it was at 12.9v?
  • Tucson is a bit warm, yes? Watch the water level and keep them plugged in. You don't need boost mode as much as you need to verify float mode at 13.2 volts.
  • What is the SG of each cell? What does Crown say the SG should be?
    Can't tell anything without knowing that.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
