westend
Mar 04, 2015Explorer
GordonThree wrote:OK, I'll defer to the switch-on-pump application. Put a separate switch in that circuit.westend wrote:
In your diagram the water pump is on the same switch as the lights. It does not need to be switched and should have larger wire than 20 AWG.
I like having a switch for my water pump. Sometimes my water tank is empty and the pump would run continuously if there was no switch.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
