wa8yxm
Mar 04, 2015Explorer III
As wired you have 120 volts going to 12 volt devices and six volts for the 12 volt circuit, In sort no it will not work
This is so far from working I wont even try to fix it but will leave it to others.
First step. Search for (using the number, not the word) Twelve volt side of life
This should bring up the basic 12 volt side of things.
You need two independent systems 12 and 120 volt, the only thing they have in common is the distribution center/converter. but you show 120 volts to the 12 volt switches.
Given the way things are made today.. I'd use 12ga wire for your 120 volt outltes and such, even if they are only 15 amp. And use real house type, not RV quick boxes.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
