Gdetrailer
Mar 04, 2015Explorer III
CoopaJade wrote:
I posted 2 questions onto the diagram. I'm not going to wire anything up until I've fully educated myself. Hopefully you can help.
You do not want to run ALL the 12V items off ONE 14 ga wire run to that switch. Besides you do not want to fuse 20ga wire at 15A, very bad things WILL happen if there is a short or even current overload on the 20 ga wire..
Instead you want to run INDIVIDUAL runs and I would bump up the wire ga to 12ga for ALL 12V regardless of the "loads" attached. You can fuse 12Ga at 20A or if you wish lower current if you want to match the expected loads but it is not really necessary to do that.
12ga on the 12V side simplifies your wiring and fusing and makes for much easier upgrades in the future (you may find the lights you have are not enough and want to add more)..
Your 120V outlets will need an inverter, the power box you have listed has two separate compartments.. One for 120V shore power and one for the 12V fuses.. There is a converter that takes 120V and converts that to 12V to charge the batteries and power the 12V circuits when there is shore power plugged in.
For an inverter you need to follow a couple of rules..
The inverter needs to be placed as close to the batteries as possible (but not in the same compartment as the batteries). This is to allow for a very short wire run to the inverter.
You need to use the largest wire size possible that the inverter will accept.
The reasons for short and large wire is voltage drop..
You only have about 2V that can be dropped until most inverters will shut down due to low battery voltage.. You don't want to waste any more of that voltage in the wire..
Instead you run a longer run of 120V wiring to the inverter, you have much less power loss at 120V than you have at 12V (hint, that is why power companies use 4800 volt or higher lines then a transformer at your home to bring that down to 120/240V)..
You will only be able to power so much from your batteries.. Don't plan to run a microwave or A/C unit from a single set of batteries as it will only take a few minutes to drain the batteries to nearly fully discharged under high wattage loads..
Buy a inverter that is large enough to power you biggest expected load.. Doing so reduces wasted power.. in other words if you need 300W to run TV, DVD, laptop don't buy a 3,000W inverter.. Buy a 500W inverter.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
