worka26673 wrote:
I have a charging problem I have a 2000 Fleetwood American eagle motorhome. I have brand new batteries 2 for the motor and 4 deep cycle 6 volts for the coach. The alternator on the motor will charge both sets. But when plugged into the 110 or generator running, it will not charge. All the 110 stuff works when plugged in. I have a Heart Freedom 20 interface inverter model 81-0271-12 grey top plate and black sides. The on off switch is on the top. No display on the unit. Also I have a remote panel a Heart Link 1000. All the lights are normal with no fault codes. Red charge light is on, the AC green light is on, the 4 green battery condition lights are on, the power inverter light is on, but the volts read 12.70 and the amps 1.1. I have no idea where or what kind of converter I have or if a converter has anything to do with the charging. Can anyone help me?
New batteries? Odds are they were connected wrong, wires left loose, or a fuse blown.
